I set up 3 finger swipe down for keyboard shortcut "Crtl + W" (or ^ W). When I trigger it in Microsoft Remote Desktop 10 client, it triggers successfully (I have feedback setup as well), but only the key "W" goes through. So each 3 finger swipe down results in typing a "W" instead of closing the current tab (via Ctrl W).
Macbook Trackpad
See my config here:
- Type of Mac: MacBook Pro (15-inch, Late 2016)
- macOS version: 10.15 Beta (19A487l)
- BetterTouchTool version: v3.086
I looked up this issue and found this Github issue which indicates it should be fixed by v2.353. I'm running v3.086 and have enabled "Shortcut sending compatibility mode", but am still not able to get it to work.
