Trying to emulate scroll button click on magic mouse for Sketchup
I mainly use BTT for Sketchup. I have a macbook and use a magic mouse with no scroll-wheel/button. Being able to use the scroll-wheel/button click for sketchup is a major workflow requirement so I use BTT to emulate this action. Currently I have the "middle click" programmed to emulate the scroll-wheel/button which allows you to orbit around your model while you're in the process of completing other actions. However, what I'm finding is that while the "middle click" is activating the orbit icon (bc the mouse pointer will change to the orbit icon) it won't actually perform the action unless I click onto white space first, when it should be a seamless transition into orbit mode. Just wondering if anyone else has experienced this or if I'm doing something wrong... I'm not the most tech savvy person out there. Hope this makes sense to someone.
This is working for me
