I have been having a lot of issues with the Tipswipe [any direction] ](two fingers fixed) gesture, some times it gets triggered and sometimes it doesn't. I used theses gestures with no issue on my old 2003 MacBook pro, but in my new MacBook Pro 2019 it is a struggle to use them.
I have tried to increase the Gesture sensibility but it does not seem to help. I have noticed that the travel of the left finger makes a difference, the longer the travel (my index finger moving up or down) I have a higher success rate. This kinda solves my problem but it is to difficult to do since the travel necessary to trigger the gestures is very uncomfortable.
Hello, I am new here. I tried BatterTouchTool but because Jitouch was still working with Catalina I have never used it,
Now it does no longer work on Big Sur - or do you know a way how to use it?
Do you know where I can find a way to use the functionality of Jitouch with BetterTouchTool?
Can't find it here… and because you had a similar problem I am asking you
—arik
I miss the Characters:
an X with three fingers (the middle one not on the trackpad) closing a Tab
three fingers (the middle one not on the trackpad) open App XY (I guess I will get this done soon)
(2 examples)
Would be very happy if I do not have to do all new
I guess I solved my problems. I have to learn some new guestures. BTT is really powerful, wow.
and its working as it should to ^^
If you there is a way to create gestures with BTT as you did in Jitouch please let me know. Cant find an entry elsewhere.
THX
three fingers: 2 fingers fix + double click with left or right finger
how possible?
