When tapping the trackpad with three fingers to middle-click, it will either work just fine, not at all, or only sometimes. There doesn't seem to be any pattern behind it.
MacBook Pro Trackpad
- Type of Mac: 2016 MacBook Pro 13"
- macOS version: 10.14 Mojave (This issue was present before updating to Mojave as well)
- BetterTouchTool version: 2.641 (950)
Attached is a screenshot of my currently enabled gestures that use three fingers. Could any of these be the culprit?
There are other bug reports on this, but no recent ones with an official response that I've seen.
Any help would be appreciated. Thanks.
