Hey Andreas,
Here's what is causing this:
Open
https://raw.githubusercontent.com/aws/aws-cli/refs/heads/develop/CHANGELOG.rst
OR
https://raw.githubusercontent.com/external-secrets/external-secrets/v0.9.11/deploy/crds/bundle.yaml
in MS Edge (my version is 146.0.3856.97 (Official build) (arm64)) -
Select any word by double click or simply hold mouse button and select.
This would cause macOS spinning ball.
Additionally it will copy the selected text into the clipboard which is not configured as an action and it is not expected. This reminds me of the following topic
If I disable the below trigger from the TextSelectionMenu CAG the copy to clipboard issue disappears, but there's still a lag when selecting a text. I need to quit BTT in order for the lag to stop.
The lag nor the copy to clipboard does not happen for "regular" (not files) sites. I've noticed this only for the above file/urls and for another file/url stored in S3. The common between these files is that they are quite long. It doesn't not happen when I open a small file, e.g. https://raw.githubusercontent.com/wezterm/wezterm/refs/heads/main/LICENSE.md
Note this doesn't happen when the same urls/files are opened in Firefox or Safari.
Here's the trigger (configured under "Automations, Named & Other Triggers"):
"BTTLastUpdatedAt" : 1775651142.149034,
"BTTTriggerConditionsFormatReadOnly" : "active_app_name != \"iScreen Shoter\"",
"BTTTriggerConditionsData" : "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_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_AsMCzgLZAuIC7AL7Av0C_gMAAwUDIwMnAz0DQgNaA14DagNvA3IDdwONAAAAAAAAAgEAAAAAAAAAZwAAAAAAAAAAAAAAAAAAA5E=",
"BTTTriggerType" : 806,
"BTTTriggerTypeDescriptionReadOnly" : "Text Selection Did Change",
"BTTTriggerTypeDescription" : "Text Selection Did Change - original",
"BTTTriggerClass" : "BTTTriggerTypeOtherTriggers",
"BTTUUID" : "B494EE2F-A724-417D-B9A7-0E180BF41E88",
"BTTNotesInsteadOfDescription" : 1,
"BTTRequiredModifierKeys" : 0,
"BTTOrder" : 0,
"BTTActionsToExecute" : [
"BTTLastUpdatedAt" : 1775650963.7147079,
"BTTTriggerParentUUID" : "B494EE2F-A724-417D-B9A7-0E180BF41E88",
"BTTIsPureAction" : true,
"BTTUUID" : "25815C32-C513-4EC0-B8C1-A87E50595BCE",
"BTTPredefinedActionType" : 330,
"BTTPredefinedActionName" : "If Condition",
"BTTOrder" : 0
"BTTLastUpdatedAt" : 1775652706.560132,
"BTTUUID" : "2EBB8DF7-72EA-4B98-B769-91DC6ADC754B",
"BTTPredefinedActionType" : 450,
"BTTPredefinedActionName" : "Update Floating Menu Properties",
"BTTAdditionalActionData" : {
"BTTMenuCategoryItemIcon" : false,
"BTTMenuCategoryItemBehavior" : false,
"BTTMenuCategoryPosition" : 1,
"BTTMenuCategorySpacing" : false,
"BTTMenuCategoryItemVisibility" : false,
"BTTMenuCategoryShadow" : false,
"BTTMenuElementIdentifier" : "",
"BTTMenuAnchorRelation" : 3,
"BTTMenuPositionRelativeTo" : 7,
"BTTMenuCategoryZIndex" : false,
"BTTMenuCategoryBackground" : false,
"BTTMenuCategoryResizeOnHover" : false,
"BTTMenuCategoryModifiers" : false,
"BTTMenuCategoryItemPositioning" : 0,
"BTTMenuPersistChanges" : 1,
"BTTMenuAnchorMenu" : 0,
"BTTMenuCategorySize" : false,
"BTTMenuItemBlurredBackground" : 1,
"BTTMenuCategoryItemSizing" : false,
"BTTMenuPositioningType" : 1,
"BTTMenuCategoryMenuVisibility" : false,
"BTTMenuAvailability" : -1,
"BTTMenuCategoryMenuOpacity" : false,
"BTTMenuOffsetY" : -15,
"BTTMenuActionMenuUUID" : "CCAFA946-6859-4A59-A6AF-8D325B9D6F98",
"BTTMenuCategoryItemSpacing" : false,
"BTTMenuCategoryBorder" : false
"BTTOrder" : 1
"BTTLastUpdatedAt" : 1764241833.9751539,
"BTTUUID" : "7FEA9DF9-47F3-41BD-A892-63787EE5654A",
"BTTPredefinedActionType" : 334,
"BTTPredefinedActionName" : "END If Condition",
"BTTOrder" : 2
"BTTLastUpdatedAt" : 1775651946.4565401,
"BTTUUID" : "C99E569C-387B-45E0-B7B6-E2F885C0C5BE",
"BTTOrder" : 3
"BTTLastUpdatedAt" : 1775652712.0509171,
"BTTUUID" : "666F9B82-A441-47DB-8920-5FF22B2E59E4",
"BTTMenuOffsetY" : 10,
"BTTMenuCategoryBorder" : false,
"BTTOrder" : 4
"BTTLastUpdatedAt" : 1775651946.4605451,
"BTTUUID" : "F2BCAB7E-8445-4F6B-A277-958A79EEBD1A",
"BTTOrder" : 5
"BTTLastUpdatedAt" : 1775651946.46117,
"BTTUUID" : "06E0B2CD-8404-4235-A64D-11AAAE2D7159",
"BTTOrder" : 6
"BTTLastUpdatedAt" : 1775652718.5878501,
"BTTUUID" : "359C44A7-852F-4F97-9BBF-98ED6A9B6353",
"BTTOrder" : 7
"BTTLastUpdatedAt" : 1775651946.462342,
"BTTUUID" : "90DCC62B-AF3D-4018-92B1-B1374A606327",
"BTTOrder" : 8
"BTTLastUpdatedAt" : 1775651946.4629169,
"BTTUUID" : "2354F67D-5E13-4AB8-AD0E-67E499F04377",
"BTTOrder" : 9
"BTTLastUpdatedAt" : 1775652721.5452762,
"BTTUUID" : "B407CC28-8BE0-423F-B49D-94AFE988F4D8",
"BTTOrder" : 10
"BTTLastUpdatedAt" : 1775651946.4642601,
"BTTUUID" : "6B4F3A0D-77C5-4432-A0F9-E7D0E07BCAD8",
"BTTOrder" : 11
"BTTLastUpdatedAt" : 1775652481.8045011,
"BTTUUID" : "EF9B6052-AC98-430C-A38E-65626F43BA95",
"BTTPredefinedActionType" : 386,
"BTTPredefinedActionName" : "Show Floating Menu",
"BTTMenuActionActivateKeyboardFocus" : 0,
"BTTMenuActionMenuID" : "text-selection",
"BTTMenuActionRestorePosition" : true
"BTTEnabled2" : 0,
"BTTOrder" : 15
"BTTGestureNotes" : "Text Selection Did Change - original",
"BTTTriggerConfig" : {
"BTTTriggerRestrictions" : "0"
BTT: 6.351
macOS: 15.7.4 (24G517)
