After importing the latest Aquatouch version, BTT is stuck in a cycle of starting, crashing, starting, crashing. CPU load is at 100%, and the crash cycle is preventing any user input.
In order to do use the system, I had to restart macos in safe mode and disable the BTT auto-start.
I then deleted the entire BTT app and downloaded and installed the latest version, in an attempt to start fresh. However, the same crash pattern is happening when I start the new version.
How do I fix this?
any
- Type of Mac: MBP 2017
- macOS version: Monterey 12.0.1
- BetterTouchTool version: 3.711
