Sort Groups & Top Level Triggers
@Andreas_Hegenberg It would be very helpful to have a sorting option for the list of Groups & Top Level Triggers. I know you can drag and drop to organise or use folders, but these require more maintanance steps.
Also is this on the to-do-list?
sorry BTT relies on the manually specified order for a lot of functionality even if not always visible.
hmmm...back to the manual drag 'n drop then, still thx for all the good BetterTouchTool brings
just to clarify a little, some examples:
  • conflict menu order depends on the order of the UI
  • visual separators depend on the manual order
  • gesture handling priority is defined by the order defined in the UI
  • for floating menus, stream deck, and touch bar the order in the UI also specifies the real order
  • key sequence handling depends on the order in special cases
  • named triggers are shown in various places ordered by their manual order
there are many more such things and this is a design decision that was made in the very first version of BTT many years ago, so this is something I really can't change :slight_smile:
I understand and value all your work and feedback. Maybe in time we could export and import the triggers in a organised way with help from H@llo.ai :wink:
