Smooth Scrolling?
Hello. I was trying to search for this but I haven't seen anything latest. Does BTT have smooth scrolling? I just downloaded it to give it a try. Currently using Mos and sane side buttons for my MX Master 3 as I don't like Logi options since it uses so much ram. Would be great to just use one app so I don't have to use mos and sane side buttons. Thanks!
I don't think so, what does smooth scrolling do?
When you scroll using the mouse scroll, without third party app like mos, it’s very choppy. I think it’s because macOS uses natural scrolling with the trackpad. Not sure. Logo options has it but I don’t like using that app. Also, I want to be able to use other mouse and have smooth scrolling.
Ah probably it translates the normal mouse line based scrolling to pixel based scrolling used in trackpad gestures etc.
I'll have a look maybe this can be supported.
Yep I think that was the reason when I was searching around. Thank you!
was this feature ever implemented? I'd love to get it on my MX 3s master mouse. The scrolling can be quite choppy
Not yet!
You can give Mac Mouse Fix a try. Very light weight, probably the best scrolling and all buttons are customizable. You can even set gesture. Only uses 19mb ram on my system. It’s $2.99 but it’s open source so if you have some dev skills, you can compile it yourself and it’s free. Also has 45 day free trial.
in fact, the mouse wheel can only function properly with either the Mos or BetterMouse software; otherwise, scrolling becomes nearly impossible. However, once BetterMouse and Mos are activated, the wheel detection in BTT either fails or experiences significant lag.
You can check that after installing and using mac mouse fix, if you set the BTT wheel for volume adjustment, you will find that when both software programs are running simultaneously, the wheel cannot smoothly adjust the volume.
Is there any news on this? Will the feature be coming? :slight_smile:
Asked this already years ago here.
This video shows the difference very nicely:
https://youtu.be/OToSkmumVM0
Smooth scrolling is now supported in v5.792 via scroll modifiers: Scroll Modifiers (Smooth Scroll, Speed, Acceleration) · GitBook
