Hi, not sure if this is a bug or feature report but if I enable "Inverse scrolling for normal mice (...)" the "smooth scrolling" is broken. If I use the Macbook's Touchpad the "smooth scrolling" works fine but with the mice unfortunately it isn't.
Normal Mice
- Type of Mac: MacBook Pro (13-inch, 2017)
- macOS version: 10.15 Catalina
- BetterTouchTool version: 3.206
