Is there any way to add single finger click as your trigger? I believe you can do it with a mouse but not on trackpad. Ofc there's an issue with not having left click anymore but maybe make you set a keyboard button to do it? It would be really useful even for a workaround. I mainly want to set 1 finger click to be right click and 1 finger force click to be left click + right click. The force click works but not the 1 finger click because theres literally no option for it and I can't find any safety settings that would unlock it.
if you remap the left-click the action in the normal mouse section, that will also apply to the trackpad. However be careful you still have another way to do a left-click.
This is the issue now BTT Single Finger force click lift finger before trigger
