I set up a force click to do right click down, and it does but when you lift pressure and redo it, it will not activate the trigger again unless you lift your finger. Is there any setting to fix this?
Edit: The thing says:
"If configured, this named trigger will be executed as soon as you remove the last touching finger from the trackpad. The named trigger can be configured in the "other triggers" section in BTT"
So same issue, is there a way to basically set it to when the force is under what is required for a force click?
