Problem with 2 monitors and snap tool since updating to MacOs Sequoia
I have a Mac Mini M1 connected to two AOC 27" monitors (one is connected through USB-C/DP, the other one with HDMI). I've been using simple snap tool for years without problems.
Since updating to MacOs Sequoia 15.0 (24A335), I have a problem snapping to the top/center of the screen: this leaves the application in a weird spot, not maximized and not entirely on one of the two monitors. By the way, while snapping the 'preview outline' that I see is correct and shows where the window should go.
Is this an issue anyone's heard of?
with macOS Sequoia BTT/BST by default integrate with the native snapping. If that causes problems you can switch back to the classic mode:
Wow, that solved it! Thank you for your amazing / fast response!
I have the same problem since the Sequoia update, the snipping leaves 10 pixels of space around the windows which should fill the space, regardless the numbers of monitor. Using classic BTT resizing doesn't solve it, do you have any other suggestions? Thank you!
@Bocha see
Thank you very much Andreas, best support ever, and I mean it!
I had the same question about the extra pixel space around each window after upgrading to Sequoia and this solved it. Thanks so much!
