Please create simple modifier keys for the Stream Deck with one click.
Current issues:
- Requires a complex macro to simulate modifier keys on the Stream Deck.
- Works partially: only one Modifier+Action (mouse or button) at a time. Need combinations like Shift+Option+...
- Command key doesn't work. Bug described here: Stream Deck ⌘Command modifier key not working.
Current solutions:
- SuperMacro Stream Deck plugin (Windows only)
- BetterTouchTool (the only option for Mac, but without an update it works partially).
- Keyboard Maestro doesn't work, and Karabiner can't be attached to Stream Deck.
