MIDI Triggers Section - Enable/Disable Selected Trigger
Hi Andreas,
Here is another bug I found in the MIDI section.
Thanks,
zorze
Description
  • Enable/Disable Selected Trigger menu item not working. In other sections (e.g. Touch Bar), disabling a trigger will show a slashed eye and the trigger text will become gray. Nothing as such in the MIDI section.
Steps
  • Top left pop-up menu > MIDI Triggers
  • Create trigger
  • Select trigger
  • Menu Edit > Enable/Disable Selected Trigger
  • No effect on trigger
Notes
  • The trigger becomes disabled only when "BTTEnabled2" is set to 0 by copying the trigger in a text editor and pasting it back in BTT. But no visual feedback.
Specs
  • BTT version : 3.366 (1584)
  • MacBook Pro (15-inch, Late 2016)
  • MacOS Mojave 10.14.6
Thanks Andreas,
You corrected this bug in version 3.373 (1597).
You're a machine!!!
