Hello every one,
I kindly ask for your help in setting magic mouse gesture (pinch in) to (zoom in).
As the only option i can choose from predefined actions is (smart zoom) but not (zoom in).
Note: in pinch-in? I get the following explanation but I don't know how to perform it
( Pinch In If you want to use this gesture for zooming you can either use the predefined actions zoom in / zoom out, or use custom keyboard shortcuts (cmd + or cmd -). This gesture may need some advanced configuration in order to work properly. Check out the advanced mouse preferences and go to the last tab (other gestures, zoom etc.))
I appreciate your assistance.
