Finally have some time to finish this release after a nightmare month
Updated first post with 0.7 release
Changelog
New - Wi-Fi and Bluetooth icons are dynamic with new icons
New - Toggle; Remind Me!: This toggle shows a dialog and asks what you need to remember. writing "325 Call Steve" will add "Call Steve" reminder for 325 minutes later on macOS reminders app. You can use up to 3 digits for minutes on first section before space. You don't have to describe a task after space if you dont have one, writing only 15 will remind with "Hey! Here is your Reminder!" title. Remind Me script automatically disables Do Not Disturb. Don't forget to enable notifications for reminders in settings. Right click on button opens Reminder App. Also you can see your reminder and can be notified from your iphone if you enabled icloud account for reminders
New - Settings icon for control center, right click opens macOS settings, also right click on apple icon for settings pane still works
New - Auto close feature. it closes Control Center window when mouse leaves
New - Experimental scroll feature added to settings pane. Scrolling with non apple mouse wheel working with this feature. it has lag but working better than before, any helps are welcome on improving DetectScrollInput() function. Higher DeltaY values causing lag but couldnt find a way to limit that. also Control Center frezing when you do quick swipe gestures
Improvement - Right click on volume slider mute / unmute now instead of set volume to 0
Improvement - More keyboard shortcuts for Control Center. Shortcut list is on first post
Improvement - NativeDisplayBrightness app changed with MonitorControl. its frequently updated app better for next releases
Fixed - Applescripts launchs faster in this release again
Fixed - Reduced CPU usage on start, compared %25 to %10. Using repainting with javascript instead of css injecting fixed this. Dark Grey, Light Grey & Contrast Orange uses less CPU compared to other appearances
Improvement - Control Center uses bettertouchtool to show notifications for Color Picker, don't forget to enable notifications settings for bettertouchtool
Known Issues - Control Center frezing when you do quick swipe gestures or mouse scrolls. It also related with BTT gesture sensivity settings
Known Issues - Copy paste not working on applescripts with dialog box (Remind Me and Color Picker). it can be solve with using app bundles instead of applescript files but i didnt add app bundles to releases because of privacy concerns, i want to keep all code open source. If you need copy-paste functions on these scripts save applescript files as app bundle then change file name in html file
Hello there, great work I have to say!
One small little problem I have: The web view window is not transparent? I attached a screenshot. Using macOS 10.13.6 and BTT 3.402
And one little neat idea: Scroll with the mouse on brightness/volume control to adjust them (like on YouTube on the volume slider)
@Future_Face open mcc settings then click open preset folder. edit mcc.html file. i use brackets app to edit html files. also you can use cmd+f to find these lines in brackets
i edited this one, you can easily replace in preset folder. don't forget to backup old one
I enabled/disabled the checkbox and restarted during this action. Sadly the bug is still there. Same bug occurs on the other extension from you for window management (SWM).
I am using an iMac End 2012 27" (Intel Core i5-3470S, 16GB, NVIDIA GeForce GTX 660M 512 MB, OS X 10.13.6)
Here the script result:
➜ networksetup -listallhardwareports
@CodeBrauer thanks for submitting result, you can delete ehernet adresses if you have privacy concerns, i need to write a script to recognize which device using which port,
does your bluetooth toggle working ?
if you can edit html file
var wrs = await ShellScript(`networksetup -getairportnetwork en0`)
var sc = 'networksetup -setairportpower en0',WDisable = sc+' off',WEnable = sc+' on'
changing these 2 lines to
var wrs = await ShellScript(`networksetup -getairportnetwork en1`)
var sc = 'networksetup -setairportpower en1',WDisable = sc+' off',WEnable = sc+' on'
should fix wireless toggle, i will add a setting for selecting which device to toggle on next releases
@Future_Face dont be hurry i shared edited file on previous post, you don't have to edit code, just replace file and don't forget to backup original one, replace back original if will not work. let me know if this will work
New - Toggle for Keyboard backlight with increase/decrease buttons.
Move your cursor to icon for + / - symbols; + Increases keyboard backlight with 2 steps,
Right clicking + increases keyboard backlight brightness to maximum level - Decreases keyboard backlight with 2 steps,
Right clicking - dims keyboard backlight to 0
New - Toggle for Microphone Mute / Unmute with dynamic icon. Right click opens microphone settings. Some chat apps can change mic level without asking, check icon on for a while before using
New - Display Mirroring toggle icon is now dynamic
Single Display / Mirrored Display / Multiple Display
New - Swipe / Scroll on sliders to set your volume or brightness level. Working smooth with trackpad but got some lag with mouse scroll
New - Siri icon changed
Improvement - Faster load on startup
Improvement - Control Center automatically detects primary Wi-Fi device port for older macs that not using en0 port
@Andreas_Hegenberg multiple requests for now playing from different presets crashing btt. aquatouch and control center couldn't work together until now playing feature disabled on one of them
