Hi together,
I recently switched from my Intel Macbook to a M2 (Max) Macbook and I didn't find any satisfying tool yet to monitor these stats. Does anyone have a recommendation? ![]()
I am posting it in this forum because I think it would be a great feature for the Stream Deck Plugin or the very awesome new floating menu !!
I already tried:
- Fancy CPU and RAM usage gauges on the StreamDeck! (Also where are all the plugins at??) (unfortunately the SystemKit didn't work. I think it just doesnt work with the M2 chip ?? GitHub - gao-sun/SystemKit: macOS system library in Swift)
- CPU Usage Monitor Widget - #13 by lennarto (I probably did the folder / file structure incorrectly)
- GitHub - marekkaczkowski/Touch-Bar-iStats: Show CPU/GPU/MEM temperature on Touch Bar with BetterTouchTool! doesnt support M1/M2 chips
- https://apps.apple.com/de/app/istat-menus/id1319778037?mt=12 works ok but doesnt support BTT
I am happy for any tip, thanks !! ![]()
