Current i work on multi screens (1 macbook, 2 external screen)
Display have separate Spaces: Off (image below**).
Apple disable menubar on non-main screen. Has big problem, in non-main screen missing menubar,
In my case, main screen set to monitor 27in, and i want to create a float menu (cloned menu on main screen).
Try with Float Menu, but can’t find any tips for it, try search on forum i found Duplicate Menu Bar on top of App Window download and build it, and tada, it’s work, but has new problem need update for compatible with new macOS (tahoe?)
Can add function from SecondBar to BTT?
