I hope I am in the right section I am using BetterSnapTool
The shortcuts I use daily I am not sure if this happened before, I don’t think so since I am a bit ocd. After updating to 15.5 I started noticing the right and left half have some padding on all sides, this doesn’t happen with thirds, or even bottom and top halves. It might be hard to see but the halfs have like 5-10px of padding around whereas the third right doesn’t. Is there anything I can configure to disable this padding, I couldn’t find anything in the configuration.
- Type of Mac: M1
- macOS version: 15.5
- BetterSnapTool version: 1.9.12
