Hyperkey often doesn’t react to first keypress; requires pressing twice
For instance, I use Hyperkey-Q to launch launch the Stream Deck app. First time nothing happens, so I do it again and it works.
This happens with both direct BTT commands (such as an application launcher), and Keyboard Maestro URL triggers.
Have you seen this before? I searched this forum and couldn’t find anything about it.
Thanks,
Russell
M1 MacBook Air, Catalina
As for Keyboard Maestro, check out the end of this post. Maybe that helps.
