I have a HyperKey (https://hyperkey.app) mapped to Capslock with following modifiers: Shift+Ctrl+Option+Cmd, but it does not seem to work with BTT. If I click a HyperKey+S instead of registering it as Shift+Ctrl+Option+Cmd+S (as in all other apps), it recognises it as Cmd+S. Typing Shift+Ctrl+Option+Cmd+S in BTT also does not help (HyperKey+S is not recognised later). All other apps (and system preferences keyboard shortcuts) work just fine.
Unfortunately BTT's Hyper Key implementation is mostly made for usage with shortcuts defined in BTT, and might sometime not work well with shortcuts defined in other apps
Oh thanks, I was not aware BTT has such functionality. I just set it up and it seems to work with my apps where I had my HyperKey defined, so very cool! It means I can uninstall HyperKey app
But how do I make use of HyperKey in BTT itself to trigger some actions ? If I add the keyboard shortcut and lets say press Capslock + S, it only recognizes it as Capslock (not HyperKey). Adding Shift+Ctrl+Option+Cmd+S in BTT won't fire the action when I press Capslock + S.
Recognizing caps lock is normal, however when pressing the modifiers while recording a new shortcut, BTT should trigger the action correctly after it was recorded.
LoL, ok, now I got your point. Yes, once I pressed modifiers + my key it works now after pressing the hyperkey. Idk why it did not work earlier, I guess BTT restart helped. Thx a lot for your help, issue closed
Looks like after Caps Lock acting as Hyperkey performs both actions: HyperKey and Caps Lock at the same time. Is there any way to stop this key to act as Caps Lock, disable its led and work fully as a Hyperkey?
That right, when using the built in keyboard the Caps Lock led is disabled but when holding the key inside a textfield it also shows the Caps Lock orange indicator on top of the field.
If for some reason the hyper key feature doesn't work well for you, I'd recommend @Frank1's approach of remapping Caps Lock to "Right Ctrl". You can then use it in shortcuts defined in BTT by enabling the "differentiate left/right modifier keys" option
