Hello,
my current plan is to keep the touchbar as stock macOS as possible, but set up BTT custom layouts that are triggered via modifier keys.
CTRL
: Touchbar presets for system controls, such as lock, brightness (display + keyboard) -
ALT
: music controls + volume sliders -
CTRL + SHIFT
: F1 … F12 keys (custom layout built in BTT) -
FN
: Emulated old Mac utility key layout (via keyboard settings in systemsettings, not BTT) -
CTRL + OPT + CMD
: Window manipulation
The default BTT touchbar layout therefore is empty.
I only added one button with the predefined action "Toggle BetterTouchTool Touch Bar" to be able to exit this custom layout.
However I've noticed that whenever I hold down either CTRL + ALT
or CTRL + Shift
that the touchbar's layout will switch to the BTT one.
How can I remove this keyboard shortcut?
Thanks a lot in advance
