Floating WebView does not work on Google websites
The Floating WebView appears to be broken on Google websites, resulting in only a perpetual loading symbol atop a white background.
An example shared preset can be found here.
  • Type of Mac: M1
  • macOS version: 13.4
  • BetterTouchTool version: 4.0.75
Seems to work fine here, are you sure your internet connection is working ok? Maybe some firewall blocking BTT?
You are correct. The prompt of the firewall was concealed behind the Floating WebView. I apologize for any inconvenience this may have caused.
