Floating Web View
Is it possible to close automatically a floating web view after a determinated time?
I mean to specify a delay time after open the floating web view, and if no shortcut or click is done in the specific delay time, close the floating web view.
Thanks a lot.
Pep
<script type="text/javascript">
  var startime = 0;
  var delay = 60; # time after which to auto-close
function BTTInitialize() {
const now = new Date();
window.startime =  now.getTime();
  function check_close()
          var remain = now.getTime()-window.startime - delay;
      if (var > 0){
          window.location.href = "bttweb://trigger_named/?trigger_name=&closeFloatingHTMLMenu=1"
   # ask to check if we have to close the page every second
   setInterval(check_close, 1000)
Now if you want that any interaction reset the timer, you just have to update the variable.
Note that i did not tested the above code, this is just to give you the idea and a way to start to implement this. Do not hesitate to post your working example
Olivie
I have done a Floating Web View that closes automatically and I am using it instead of HUD Overlay.
I have shared the code here:
