I have "2 fingers scroll down" gesture for my magic mouse.
And "Disable 2 finger scrolling if 2 finger up / down swipes are used" is checked.
But 2 finger scrolling is still active.
Is this a bug?
Hi, even with the new ui, I still encounter the same problem as described in the thread. I tried to restart BTT, restart my macbook pro 2016, assign new gestures to the 2 fingers swipe up/down but it keeps scrolling even with every gestures I try to assign. I just want to disable the 2 fingers scrolling completely to assign other features to it
oh sorry I missed this.
If you want to disable two finger scrolling you need to click on the app you want to disable it for, then in the right side-bar select âdisable two finger scrollingâ. Did you already try this?
No problem for the delay Thanks for taking your time to help me.
I've tried a lot of things in the options but nothing seems to resolve my issue.
i just tried what you told me but I don't see the option on the right to disable 2 fingers scrolling. I want to disable it for all my apps but I tried with a single app (pdf expert) and I don't see the option (see the ne next screenshot):
I have also disabled 2 fingers scrolling in the magic mouse settings and it still triggers 2 fingers scrolling with the other triggers I have assigned to two fingers scrolling (both up and down) (see the picture for my settings)
Hi Mr. Hegenber, did you have some time to look at this issue? I just want to say I would be really grateful it this bug was to be fixed one day. Take your time and I don't want to rush yourself. You've got clearly more important things to do than resolve this simple bug but it would be really helpful with my day to day workflow at uni. Thanks for your hard work and have a nice day!
P.-S. Are you happy apple decided to keep the touch bar with the new 16 inch mb pro?
