"Custom Move / Resize" fails to move to Main Monitor. The window flashes to the main Display and then back to the monitor it was in originally.
My setup:
- External (Main Display),
- Sidecar (Monitor 2, placed to the left of Main)
- Internal (Monitor 3, placed below Main)
I have triggers for moving windows to monitor 2 and 3, and those work fine.
Seems to be the same as reported here: Window will not move to primary display with Custom Move/Resize
- Type of Mac: Macbook Pro 2021 16" M1 Max
- macOS version: 14.4.1
- BetterTouchTool version: 4.664
