Note:
I have latest alpha version.
After waking from sleep, custom gestures are not working, unless I restart, or simply just open BTT again.
I'm using only trackpad gestures, and these are not working
- Type of Mac: MacBook Pro 14 2021
- macOS version: 14.1 (23B74)
- BetterTouchTool version: 4.299
could you try whether 4.307 does help in your case?
Does this happen after every sleep?
I'm installing the update, and will let you know if it helped.
It does not happen every time, I would say 1 in 3 wake ups it stops responding to gestures.
I must confirm, that after installing the update, the issue is unfortunately still happening. I would say that it's not that often, but still happening.
Did you install 4.307 or the 4.308 which was release shorty after?
4.307, I will install the .308 and will verify again. Thank you for quick response!
Thank you! After testing with 4.307 I found what I think was the underlying issue and fixed it in 4.308. There have been a few positive reports already, let's hope this also fixes your issue.
Seems like everything is fine so far!
