Clicks are not being registered despite me clicking my trackpad as normal. I've been a longtime BTT user and it only just started happening. Quitting BTT fixes the issue.
MacBook Trackpad and Magic Trackpad, don't have a mouse to test with
This is a screen capture of me clicking and dragging on the Desktop. Each time the cursor is moving from one corner to another, I am clicking and dragging. You can see not all clicks are being registered.
Type of Mac: MacBook Pro
macOS version: 10.14.3
BetterTouchTool version: 2.717
I only have two global gestures defined in BTT (and tried disabling all features in BTT I don't use) and I haven't installed any new mouse-related utilities or apps. I tried disabling all other apps that are listed in Security & Privacy > Accessibility and that didn't help either.
Yep, I don't think there has been a change in BTT that could cause this, thus downgrading probably won't help. However such issues are often caused by conflicting other apps or my malfunctioning hardware.
To rule out a trackpad problem, could you check if the BTT Live View shows any "phantom touches"? (Touches while you are not actively touching the trackpad)
Can you think of any other, maybe even non mouse related app you have recently installed and running? Problematic apps include such that listen for global keyboard, mouse or touch events.
You could also go to the about tab in BTT and click the "Export Debug Information" button. This will create a folder called BetterTouchToolDebug. The logs in that folder will allow me t o see whether clicks have actively been blocked by BTT (and why).
If possible please send that to andreas@folivora.ai
The apps I use that listen for global keyboard shortcuts are ones I've used for a long time, like Launchbar or Dash. Also they are the first apps I tried quitting to see if it would fix the issue before I created post.
I installed 1Password and Zoom recently for work. Quitting 1Password doesn't fix the issue and I don't keep Zoom open if I'm not using it. There's something my work installed on my computer called "Malwarebytes" that has been installed for a couple weeks and worked with BTT without issue.
Also I'm a developer, is there a way to trail some logs or something and see what else is listening to global keyboard, mouse or touch events? Console?
4 is to ensure some gestures don't produce clicks (especially three finger clicks and four finger tap sequences). This shouldn't cause your issues however.
Ah! I had an Anker Qi charger plugged into my computer via a dongle. Disconnecting that solved the issue! My guess is that it was messing up because it's only a power USB device? Man, what a wild bug. Thanks for your help!
Yeah these are always hard to find
I will add a notification for such cases to BTT in one of the next versions. (these constantly disconnecting devices also cause quite a bit of cpu usage on macos)
Maybe the usb port couldn't provide enough power for the charger?
