Bug: Values are not saved.
Values greater than 10 seconds are not saved when entered manually. This happens even if you click in another field before clicking “Save.” At least, that's the case here.
Check that link.
AFAIK it is only a cosmetic issue. If you set 20 seconds, you will see 10 seconds in the BTT field, but the "engine" will count 20 seconds.
