Maximum hold time for Trigger on Mouse Up
BTT 5,072 on Sonoma 14,7,2
Normal Mouse Configuration > Advanced > Trigger on Mouse Up
If I set the maximum hold time to higher values than 10 seconds (i.e. 120 seconds), BTT waits correctly for that 120 seconds, but the UI shows 10 s.
@Andreas_Hegenberg did you check this issue?
@Andreas_Hegenberg
Version 5,255 still with this issue.
Just a kind reminder…
Hi @Andreas_Hegenberg
This issue is still not fixed. Could you fix it in future updates please?
@Andreas_Hegenberg
Could you check this issue please?
I'm running BTT v5.752
This issue is still existing.
@Andreas_Hegenberg are you aware of it?
yes, it's on my todo list (however with low priority ;-))
