Hi all,
I’ve been using BetterTouchTool alongside Typinator for a while now, and I’ve run into a strange issue I’m hoping someone here can help with or shed some light on.
When I type into a BetterTouchTool floating window, Typinator sometimes expands text snippets in the background application instead of the floating window. The problem seems to stem from macOS still recognizing the background app (say, AppA) as the “active” one, even though I’m clearly typing into the BTT floating window.
It doesn’t happen every time, but often enough to be frustrating. Occasionally restarting BTT and Typinator helps temporarily, but not consistently.
I'm wondering:
- Is there a way for BTT to make its floating window register as the frontmost (or active) app while typing?
- Or is there an alternative way to handle input in floating windows that avoids this focus issue?
Would really appreciate any suggestions or ideas. Thanks!
