Here's my working copy of GC-BTT, maybe you could set the Notification Center Key in the Menu Bar activation group properly and I can go from there? I feel like there's a bug in here somewhere, haha. GoldenChaos-BTT.bttpresetcompressed.bttpresetcompressed (19.2 MB)
Ah I think I see.
The problem is that you'd need to change all the items you have in the global section configured. Unfortunately that was the only way to implement this change without breaking existing stuff.
Have a look at this modification (I didn't change everything yet, but it should show the idea): goldenchaostest.bttpreset (34.4 MB)
2.681 appears to have broken "Also show in any Touch Bar group that is opened." It was working on 2.67x but now my widgets that have that toggled don't stick around when I open a Touch Bar group.
My Conditional Activation groups with 'activeTouchBarGroup' conditions within them keep resetting themselves.......
I'm not sure how to send you something that would help you figure this one out. Let me know what you need!
It seems to happened on preset switch just then, to an older version of AQT where the new conditions were not present. Interestingly though, all conditions were erased, not just the new conditions.
I tried to reproduce this, but were unable to or maybe I misunderstand something.
If you can reproduce this it would be great if you'd go to the about tab in BTT and click the "Export Debug Information" button. This will create a folder called BetterTouchToolDebug on your desktop that you can send to me (andreas@folivora.ai)
Switching to some older version of the same preset (possibly same uuids, although the importer should automatically assign new ones if duplicates happen) could maybe lead to problems. @GoldenChaos always recommends to delete any previous versions of the same preset.
But just switching presets doesn't seem to break things:
Ah I do have older versions loaded, as well as a heap of other user-modded variations. Maybe these which don't have the new stuff set is rewriting the new one when changing the preset. I'll see how I can get around that!
It's getting worse, some apps are completley disappearing.
My mistake probably, I was deleting irrelevant stuff from the other users AQT variations so I can more easily merge them, but some things on my version are disappearing as well. It seems to correlate to what I've deleted but only some are going away.
Luckily I have backups though, but it will be a bit annoying to redo the CAgroup rules. At least I didn't loose much.
