BetterSnapTool maximize not maximizing
Not sure what has changed but BetterSnapTool now leaves a gap around a window that I set to maximize. Under Customizations, I have tried the resize classic and new setting along with setting empty space to 0 px and checked no padding. But when I drag a window to the top, it expands to almost the full screen but leaves a border around the window. It is very annoying and not sure when this behavior changed. I want to use every pixel for that window and I don't want to see what is around the edges the window. I thought at one point I had it set but after a reset it is back to this annoying behavior. If I can't get this fixed I will be seeking a better solution.
have a look here:
Thank you for the quick reply. I am not sure who came up with this margin thing but it should be off by default, grrr. I think the Use Classic BTT Window Resizing option is what worked initially but after a computer restart it went back to its old behavior. But I found the setting now in the new travesty of System Settings and it is now off. The tiled icons were so much better than this stupid long list thing of settings. But, thank you for the support.
