Better Mission Control & Immediately Show Desktop Preview
I don't know about you, but I don't like the delay and how the screen jumps down when using the "Mission Control & Immediately Show Desktop Preview" action.
I was messing around the other day and found that macOS seems to render the desktop previews automatically if you invoke mission control while the mouse is in the menu bar.
So I created this sequence in BTT and assigned it to the 4-finger swipe up gesture (turning off the native gesture in trackpad preferences):
Note that the X coordinate of the move mouse step (2) is just somewhere near the (top) middle of my big monitor - it can be anywhere you want (in the menu bar).
Note also that the delay of 0.00 seconds (step 4) seemed to be necessary on my iMac. It may or may not be needed on other computers, or may need to add some actual delay.
This is working great for me and more or less back to the good old days of when macOS natively did this for you.
EDIT: since posting this I've noticed that there was some unreliability in the desktop previews being rendered with the delay of 0.00 seconds so I've now changed it to 0.10 seconds and it seems more reliable. I imagine the best value for the delay could be different depending on your CPU and/or GPU.
This is awesome thank you!
Brilliant!
My goodness - this had bothered me for ages. So much as that I preferred to simply keep using manual mouse movement to preview the desktops! I should have checked out this forum years ago.
Problem solved now, anyhow. It works flawslessly. Thanks for sharing!
Updated this to behave more like the native function: swipe up for Mission Control, swipe down for App Expose, and reverse swipe to from each restore the normal desktop view.
I use this with three-finger swipe, and configure four-finger swipe in MacOS Settings to bail me out if something goes wrong. However, it's only glitched once in the last year.
I also have three-finger swipe sensitivity set to zero in BTT Settings > Trackpad > Swipes. I use the native three-finger swipe left and right to change spaces, so sensitivity only affects these Mission Control/App Expose triggers.
(Made this a while ago and don't recall all the issues it addresses. Think I had to add the App Expose trigger to avoid swiping up from App Expose directly into Mission Control instead of the desktop. Using keyboard shortcuts instead of BTT builtins solved... something.)
Mission Control instant preview.bttpreset (7.3 KB)
This works amazingly well, thank you
I never tried adding 0 second delays before
It works amazingly, just one suggestion.
I think the position the mouse is sent to should be set to X:-1px Y:-20px from upper right corner of screen. This way it's more universal and can work across different screens (MacBooks with notch and rounded corners or regular screens). And with cursor border set to black and cursor set to white in system settings, the cursor doesn't appear in the top for a split second (because it's in the right side and mostly hidden). This way it feels more native.
Hi, just to add for anyone who comes across this thread in future:
This method, including the variations in this thread, was unfortunately not 100% reliable for me. I had to occasionally manually move my mouse up to the top to trigger the previews.
Also, the mouse movement, whilst near instant, was not quite absolutely instant, which meant my eyes sometimes noticed a jerky mouse movement, which was distracting at times.
The solution I ended up doing: MacOS seems to show previews by default when you create above X number of desktops. On my laptop (MacBook Pro 15"), this requires 14 desktops. In other words, from 1 to 13 desktops, MacOS by default hides the desktop thumbnails. However, 14 desktop and above, it will automatically show desktop thumbnails.
The only downside to this method is that it makes the thumbnails small, but in my experience I can still easily tell which desktop it is I want to switch to.
That's an interesting 'hacky' workaround but indeed it works like a charm! Fyi: I have MacBook Pro 16" and here it requires 14 desktops as well.
Thank you very much for sharing your insights @SteveH
