At the login page, I'm able to login. Note: my password includes lower case "a". Right after login, since I have BetterTouchTool as a login item, the lower case "a" does not work. It works if I use Shift+A, which results, obviously, in "A".
I then tried using Capitals Lock and "A", That does not work either. The only thing that works is Shift+A. Weird. I then decided to uninstall and reinstall BetterTouchTool. That was a disaster. From that point forward, my Mac would simply lock up at startup. At this point, my only solution was to leave BetterTouch disabled.
Please advise. Thank you, Raphael
All Mac keyboards that I have (1 Magic Keyboard and 2 regular full-length wired Mac keyboards). Currently using Magic wireless keyboard.
- Type of Mac: iMac (27-inch, Late 2012)
- macOS version: Mojave 10.14 Beta (18A377a)
- BetterTouchTool version: Latest, I believe.
Yes, restarted several times.
Thanks, Raphael
