Hi, as few others already mentioned I also have problems with the "zoom" trackpad function. Every now and then I have to turn off and turn the "zoom in or out" back under the "system preferences" to regain the functionality of the zooming feature. I have the latest updated version of the BTT and do not have installed "magnet" as some on the reddit webpage mentioned as potential problems.
Regards
Do you happen to use the macOS app Magnet (a window manager). It's known to cause this issue. Deleting the app fixed this issue for me permanently.
Thank you for your reply.
No, I don't have that app but I do have Divvy app that does the same thing like Magnet (window manager). Or, of course, some other app can cause the problem...
