Since the macOS 27 release, the four-finger swipe up gesture to invoke Mission Control has been broken when using any of the Zero Finger Gestures for the trackpad combined with mouse actions. It also messes with the functionality of dragging windows to other desktops in the top preview of Mission Control to where when the three fingers are released, the window just sits on top of the preview without it actually getting sent there.
I use this with the Left Click (At Current Mouse Position) to remove the delay that macOS has when releasing a three-finger drag. Prior to macOS 27 this worked flawlessly.
The gesture to invoke Mission Control will work if the pointer is positioned over the menu bar oddly enough.
I always recommend against using hacks to get rid of the delay. It interferes with the very fundamentals of macOS mouse system thus such issues happen all the time (this specific one is probably caused by Mission Control rewrite on macOS 27 - they added a whole new gesture subsystem for supporting the touchscreen MBP, which makes things much more complex).
Unfortunately I don't think there is a solution to this.
I figured it had to do with their Mission Control rewrite (I've seen numerous reports of people having issues with it in 27).
I did some searching around and came across 3FDragUnstuck and tried it out. It works well and Mission Control still functions mostly as expected (still a little finicky when moving windows to other desktops, but invoking MC works consistently). The way that project does it is by using a leftMouseUp event instead of a full click like my workaround in BTT. I see that there are keyboard key up actions available so I'm wondering if mouse button up actions could be added? That way I can continue to use BTT for this "hack" instead of needing to run something else just for this one thing. If not, it's not a big deal and I appreciate your time!
BTT does have such actions (The "Custom Mouse Buttons & Modifiers" action). However injecting wrong up events does also lead to issues (the system often auto corrects invalid state, but there are always some things that stop working and tracking down the culprit after a few weeks of using such a hack can be really annoying)
Huh, well look at that. Using that has pretty much solved my issue! I know it's hacky, but I work in Figma and am constantly dragging things around a canvas and the split second of waiting when releasing a drag is super annoying and really adds up so I think I'd lose my mind if I weren't able to get rid of it in some way. Anyway, thanks for your help!
