Wrong behavior when copying
@Andreas_Hegenberg Copy and paste with empty groups works as always.
But if an action is present, then the action is duplicated instead of the group.
Copy
Paste
I can't test right now, but I think if no shortcut is assigned BTT assumes you just want to copy the action. As soon as a shortcut is assigned it should copy correctly
True :rofl: But isn't that a bit strange? BTT assumes ... I as a user assume that what is highlighted is copied. Anyway now I know. Thanks :slight_smile:
It's a bit complicated, this is an artifact of the datamodel from 2009 which was never supposed to do what it is used for now :smiley:
But I agree, I'll check whether I can somehow fix this.
