Working middle-click 3 finger drag for 2025? #cad
I've seen this discussed a bunch, with no working fixes detailed.
I'm trying to get a middle-click drag for OnShape/CAD.
I'm using 3 finger drag, tap for clicks in Macos and have enabled:
I've tried multiple different 2 and 3 click options in BTT, tried w suggested profile below, didn't work, then tried adding a preset for taps, another for clicks (as someone else suggested) then had all presets triggered by option key, restarted BTT, and again nothing happens, no behaviour from normal 3-finger for either taps or clicks (working fine after enabling middle-click on non apple mouse in BTT, btw).
Macbook AIr, Sequoia 15.2
BetterTouchTool: 5.067
The preset you linked still works fine in general. However the system three finger dragging breaks a lot of things in BTT because it changes the fundamental behavior of the trackpad, maybe it's causing issues with this as well.
Or maybe it's just a misunderstanding on how the preset works? Basically you need to click with three fingers, then remove two of the three fingers and move the remaining finger to drag.
I unfortunately haven't been able to get it to work in any of the ways, or others have detailed, and I don't seem to be alone in that :man_shrugging:.
I'm only trying in OnShape, which is in browser, is that an issue? (easy to sign up and test).
I ideally simply want the 3 finger tap to emulate middle mouse down and drag, with a hotkey.
If I can still keep the 3 finger functionlity by disabling, then activating to the same effect in BTT, I'm down with that.
Seems to work ok here with the standard preset:
This is my fingers while trying:
But yes, most likely it's being broken my three finger dragging, if you can, try to disable that.
