Yess, that's also something I need (but haven't implemented yet because it's not super easy...)
Hi @Andreas_Hegenberg! Few times a day, the mouse support for Touch Bar stops working. It has been like this since a few alpha versions, I don't know if it was the case when it has been first introduced.
It looks like this and don't move at all:
Every time, restarting BTT solves the issue.
Interesting, does the Touch Bar in general still work when this happens?
Yes, everything except the mouse support works.
Might be related (or not, since it doesn't happened at the same time), but sometimes after Mac wake, the BTT Touch Bar has difficulties to replace the stock Touch Bar. BTT is running fine but the Touch Bar stays stock. In this case restarting BTT doesn't help, I think I got it fixed by rebooting computer or toggling BTT Touch Bar support ON/OFF. I initially thought it might be related to the BTT option "No restart after sleep" but even with it disabled I've faced the issue. But as I said, I don't think these two issues are related.
Here is some additional information about that second issue where Touch Bar support is broken: I'd say it happens once every 10 wake from sleep. When it happens, restarting BTT doesn't help. The only fix is to disable TouchBar support, restart BTT, enable again, restart BTT.
It's a great app. 24€ maybe a bit overkill for the functionality I use (snap, cmd-drag & alt-resize), but it's lifetime. Forum's also nice, and good too see the dev active.
huh, it is getting a bit quiet. I was used to bizar frequent updates, so one gets a bit curious what is going on...
had our first baby boy
I’ll be back soon!
Congratulations! That explains any delays in your release schedule. LOL
Good times, and all I ever say, If being a dad is easy... you're doing it wrong.
Thanks
So far he is very easy to handle, but I think this might change
Well, coding with a baby sleeping on my chest is working better than I expected, so I'm slowly back!
Just uploaded 3.210:
- Some adjustments for better compatibility with 16" Macbook Pro
- Trying to figure out what's causing this: Version 3.202 doesn't restore touch bar after sleep (added some debug stuff)
More things coming soon!
My Update failed. Also note, took a long time to download (very slow compared to normal).
Ah sorry, should be fixed by now. (Although I don't know about the download speed, it's currently fast here in Germany, maybe some temporary routing issue)
Looks like 3.210 finally installed and now 3.211 fails to start download and presents the install failure.
Confirmation here. 3.211 doesn't want to download.
I have an "old" 15" MacBook Pro here. @Andreas_Hegenberg you have some issues with the esc key man! There should be a 5px space after the escape button, but my personalized buttons start at the same level then the esc key! I think BTT doesn't get that this is a model w/o physical esc key.
You mean in 3.210? (I think 3.211 should recognize the Touch Bar type correctly, I was having some issues with the upload process - should be working in a few minutes)
Yep, it should now update again to v3.212
It does! But so does the disposition of the keys on my Touch Bar
*8px i believe
Been playing around with SideCar on Catalina.
Two things I noticed:
- The iPad displays the normal TouchBar buttons for the focused application that is on the iPad (I quite like this as now I can have both the application buttons on the iPad and the BTT bar active on the Mac).
- If it is possible to have the BTT TouchBar appear on SideCar, then it would be nice to have a separate configuration toggle for enabling that.
- When the iPad is used as an extended display, moving the mouse to the bottom edge of the iPad will active the yellow dot "Mouse mode" for BTT on the Mac's TouchBar (I imagine this will need the same check that you currently do for secondary displays)
