"Window under cursor" not working with mouse gesture
When drawing a mouse gesture and using any action affecting the "window under cursor", the window is not identified correctly when the finishing point of the gesture is inside the drawing area.
E.g.: When drawing a gesture to minimize a window, the window is only minimized when the finishing point of the gesture is (A) in the desired windows and (B) outside the drawing area. If the gesture ends within the drawing area, the action to minimize the window (or whatever else) is applied to BTT itself since in this case the window under the cursor is a BTT window.
Desired behaviour: Ignore the BTT drawing area window and apply action to "real" window under cursor.
Affected system: Apple Macbooc Air M1, macOS Ventura 13.3.1
having same issue and posted about it. none of the 'under cursors' are working, quit or minimize. tried work arounds ie send shortcut to app but noe work. Only hide all windows works
Should be fixed with the next update!
okay cool. thanks for the quick response. just wanted to make sure I wasnt going crazy lol and it wasnt working anymore. look forward to it and thanks again!
Im having issue minimizing under cursor only with Adobe Apps. I'm using the three fingers down on a Magic Mouse 2 on M2 MacBook Pro 16" MacOS Ventura 13.4.1
On a side note, I'm also having to restart BTT sometimes when scrolling no longer works, it fixes itself after BTT restart.
Version 4.458
I have a 1-step macro that uses option + middle click to "minimize window under cursor"
Worked 100% for years, but now It is failing about half the time. Maybe moreso on certain apps like Omnifocus and Safari.
I can make it work if I am hovering over that windows toolbar at the top. But if I am hovering over the content in the window, its about 50/50.
I have another that uses plain middle click to "hide app under cursor" and it works fine.
WORKAROUND: Changing the action to "bring window to front and send command+m"
mhm opt+middle click should be unrelated to the issue discussed above. For drawing gestures the problem was that their overlay was recognized as the "window under cursor", causing the issue.
I just tried it, but it seems to work fine here (at least with the apps I'm using, including Safari). Is your BTT enabled in System Settings => Privacy & Security => Accessibility?
Yes. I believe OmniFocus 4 is the main culprit. I had to do a similar workaround to get "hide app under cursor" to work for it too.
EDIT: no, its several apps. Spotify is another. I have to click ~5 times to get it to activate
I am suspecting the issue is caused by HazeOver.app (it dims background applications).
that sounds very plausible, maybe they forgot to turn off the accessibility features of the overlay window they use to dim the screen. In that case BTT would see the HazeOver app‘s window as window under cursor.
unfortunately if that’s the case, it could only be fixed by HazeOver. You could verify with the conditional activation group „hovered ui element“ viewer in BTT
"hovered ui element" isn't indicating Hazeover. And a restart of BTT always usually fixes it.
Example
  • I use a one-action macro: middle click mouse = "hide app under cursor"
  • have Notion open, middle click mouse. click it 10 times, nothing happens. If I move the mouse, eventually that gets it working.
  • Restart BTT, now middle click always usually works
Update: It is very dependent on precise location of cursor.
Please see attached video to watch this bug in action.
HazeOver is disabled and quit. BTT was just restarted. You can see each time I middle click because I also added "dim screen" (just as a way to show that I am clicking)
Standby for video upload...
Difficulty uploading video file here. It will finish uploading to this link in a few mins -> Shared with BTT forum - pCloud
Also just realized I'm using v4.504 because BTT never auto-updates for me : (
Are you possibly using floating webviews in BTT? There was a bugfix sometime after 4.504 related to hidden floating webviews that could influence this.
I did have your ChatGPT floating menu enabled, used it a few months ago. Will delete.
updating to a newer BTT version should also do the trick
I can confirm the bug reported in this thread. The “Activate/Bring to Front Window Under Cursor” action does not work when triggered by mouse gestures, but works perfectly when triggered by mouse buttons.
Action sequence:
  1. Activate/Bring to Front Window Under Cursor
  2. Send Keyboard Shortcut: ⌘W
    Goal: Close tabs/windows under cursor, even when they’re in background/inactive
    Results:
    :cross_mark: With Mouse Gesture trigger:
    • Does not work at all
    • No window activation occurs
    • The action appears to target BTT’s drawing overlay instead of the actual window beneath
    • Ending the gesture outside the drawing area does NOT fix the issue
    :white_check_mark: With Middle Mouse Button trigger:
    • Works flawlessly on all apps (Safari, Chrome, Finder, etc.)
    • Reliably activates background windows
    • Correctly closes tabs when available, otherwise closes the window
    • No delay needed - instant and perfect behavior
    System:
    • macOS (current)
    • BetterTouchTool (latest version)
    • Logitech mouse via Logitech Options/G Hub
Expected Behavior: The gesture trigger should ignore BTT’s own drawing overlay window and apply the action to the actual window under the cursor, just like mouse button triggers do.
This limitation makes mouse gestures unusable for any “window under cursor” actions, which is a shame since gestures feel more natural and visually appealing than button clicks. Also I love them. :nerd_face:
have you already tried the latest alpha versions? It is working for me fine again with these.
If not I might need to increase the delay a bit more (it is very strange that this got so much slower on Tahoe, but I guess that is a system bug)
Thank you so much, Andreas!
I just tested the latest alpha version and can confirm the issue is completely fixed! :tada:
The mouse gesture now works perfectly:
• “Activate/Bring to Front Window Under Cursor” followed by ⌘W
• Works flawlessly on background windows across all apps tested
• Even without any delay (I assume there’s some built-in timing as you mentioned)
• The gesture drawing no longer interferes with cursor detection
I honestly didn’t expect such a quick response, let alone a same-day fix suggestion. Your dedication to BetterTouchTool and the community is genuinely impressive. This kind of responsive support and development is rare, and it’s exactly why BTT is such an essential tool.
Thank you for taking the time to address this so quickly and for continuously improving an already amazing app. The gesture-based workflow is now exactly what I envisioned, and it works beautifully.
Much appreciated! :folded_hands:
