When using the Window switcher with the option “Sort: Last Used / Stack Order …” it would be very nice to be able to set the setting “Initial Focus” to start in the second entry of the list. This would replicate the behaviour of the usual macOS app switcher, where one taps cmd+tab to switch to the last active app. I would also like to use something like option+tab to switch to the last active window or hold option and cycle through the list hitting tab multiple times. Currently, I always have to hit tab twice to go to the last active window (cycling through the list afterwards works very well).
required!
Thank you for pointing out the solution.
