I have three finger tap to Window Snap active window to the left half of the screen, and four finger tap to do the same but to the right half of the screen. When I click on a link in e.g. an email, whilst the page is loading the window snapping doesn't happen. I've used the HUD display to check that BTT is recognising the gesture, which it does. However, I have to wait until the page has finished loading until it then actually does the gesture.
MacBook Pro Trackpad
- Type of Mac: MacBook Pro 15" mid 2015
- macOS version: Monterey 12.6.5
- BetterTouchTool version: (please post the exact version - not just "the latest one") 4.075
