Note:
I have 2 monitors: external 4K, and macbook air m1 default display.
When I have full-sized window on my 4k monitor, the action 'Move window to next monitor' does not work. When I make the window smaller, it is possible to move it.
It seems like the window is not moved if its dimensions are greater then the resolution of the target monitor.
instead the window get resized to strange size and offset and cannot be moved to next monitor neither with 'Maximize window to next monitor'
- Type of Mac: MBA M1
- macOS version: sequoia developer beta (but I don't suspect the os version to be the cause)
- 4.649
