Will there be a feature to do "back" and "forward" for normal mice buttons?
I currently use SaneSideButtons to get "back" and "forward" for my logitech M510 mouse on macOS.
It replaced extremely bloated Logitech software that I could never trust.
It would be nice if BTT supported this. I looked at the current alpha and it didn't seem to, but I might have missed it.
Are there plans for this?
Thanks.
You can use the "Page Forward" and "Page Backward" actions. (3F Swipe)
Having a heck of a time figuring it out. I'm sure I'm being dense. Is there a tutorial for this somewhere? Thanks.
you just need to search the list of predefined actions for "forward" then you'll see the 3f swipe (page forward) action
I can find the action, I can't find the way to associate it with the mouse button.
EDIT: I probably wasn't clear, I'm talking about the side buttons, not the regular left/right mouse buttons.
I assume you're talking about the "Normal Mouse" config, too.
hi! @envoy510 did you figure it out?
I also have m510 mouse but I can't make those tilt clicks work
I ended up using an application called SaneSideButtons.
This should be easy to setup in BTT as well:
SideButtons.bttpreset (3.0 KB)
