When at home this issue does not present it itself - but at work offshore with flakey wifi and some vpn usage, frequently find BTT does not resume after my Macbook is closed then reopened. Even after screensaver activates, sometimes.
It seems related to wifi and vpn :- if macbook is restarted/resmued and BTT is not working, then if i command-space to relaunch BTT and BTT does NOT work/launch, then once wifi is toggled off, then BTT screen appears and BTT works again. It's been a long term irritation which probably isn't apparent with normal good wifi.
MacBook Air M1 OS 14.4.1 (been issue from many previous versions)
BTT Version 4.504
BTT is the best - if more/all Macbook users had it, they'd still have that touchbar in production
Note:
- Type of Mac:
- macOS version:
