I think these are the conditions most people will use
I'm really having a hard time trying to understand your posts. Maybe it's a translation thing.
Could you try to explain a little bit more?
oh sorry...
When adding something, the first item on the left is added randomly and the middle item is added with "is", but it would be nice if "hovered" and "contains" were the default values, as they are the ones we expect most people to use the most.
that makes sense, I'll change that ![]()
Thanks a lot!
