Why does BTT keep getting removed from my Users&Groups Login Items? And why does it crash periodically?
I don't know if this is just random but BTT occasionally gets removed from my upper bar (presumably crashed? I don't know). Is this a "thing"?
And why does it get removed from my login items all the time? I can't afix it to startup tasks, even after toggling lock
You need to activate the "launch BetterTouchTool on startup" in the BTT settings.
After I activate the "launch BetterTouchTool on startup" in BTT settings, then restart
• BTT does not start up
• in System Preferences, Users & Groups, Login Items BTT is described as "kind unknown" with a yellow triangle. Hovering on the triangle → "This item couldn't be found."
I've successfully run Disk Repair in recovery mode → no errors. Same result as above when I restart. Spotlight can find and open BTT with no problem.
Please also see my post a few days ago in Discussion & Questions:
starting over with BTT but keep current triggers & actions?
