I have a small external macro-keypad which is configured as a "Generic Device" (I just found it worked better that way).
I have key5
of the keypad configured to perform one action at the Global
scope, and the same key configured to perform a different action assigned to a specific application. The Global scope action seems to take precedence over the application scope. Is that expected?
I wasn't sure if BTT supported a form of "cascading scope" - so that if the same key was assigned twice, Global would be used unless a specific application also had the same key configured - in which case, assuming I was using the specified application, the action for the application would be used instead of the global one.
Thanks
