According to the settings, BTT can sync using iCloud Drive or Dropbox. Both seem to come with a red, centered aligned warning .
Which of the 2 solutions should I try?
with gratitude,
Alex
with gratitude,
Alex
none
I‘m working on a better sync solution, but it‘s not yet ready
I just lost a bunch of settings with the iCloud Drive one ... everything I have worked on in the last 2 hours
Having to go again through creating all the menus for clipboard and text transformations and having to deal with the very buggy UI makes me feel very frustrated.
I know it won't help you. I'm not sure it helps me either... but I feel like crying
that’s why it says very experimental and advises to create a backup first
But I’ll remove that sync option soon, I think a macOS update finally broke it
I am staring at that screen right now and I'm not seeing any buttons to create a backup.
I went through all the settings and I did not find an option to create a backup.
How can I create a backup?
you can import/export your presets (Presets · GitBook )
Do you maybe have Apple‘s Time Machine backup active (or another backup tool)? Then you might also be able to roll back. BTT saves all the config in ~/Library/Application Support/BetterTouchTool (this folder can also be copied manually to create a backup)
FWIW, I was having sync issues with Dropbox today (would not load settings from Dropbox setup on Machine 1 to Machine 2), and after many resyncs and waiting, I gave up and switched to iCloud.
Still works, I think (unless I was seeing delayed syncs coming in from Dropbox AFTER i switched to the iCloud option).
hey there andreas, any news on this ?
curious about a sync solution as well
any update on best sync solution?
